Hello,
I looked at the specs for the 6240 and it certainly is full featured. The one thing I was not thrilled about is the receivers weight, 18 pounds. When a receiver weighs that little, it brings into question the power supply and the amount of filter capacitance.
When a receiver has a relatively small power supply, continuous high volume listening can be problematic. Much of this depends on the size of your room, the efficiency of your speakers, and preferred listening volume.
The good thing is you bought it at Costco so if it does not meet your needs, there will not be an issue in returning it. I would run it through its paces and see if it meets your needs.
Polk Audio, while quality speakers, are not super efficient. That is they require a bit of current to sound their best and play loud. Now, if you were running Klipsch's which are ultra efficient, this would not even be a concern.
Cheers,
JJ
