1 - 15 of 15 Posts
Hi,
I am trying to connect a PC (Radeon 3870 with dvi to hdmi connector and a hdmi to hdmi cable) to my new Yamaha RX-V3800 receiver.
The PC was connected to the TV set directly until now. (all worked fine)
I have changed the setting in the receiver so that the input would be the hdmi.
When I turn on the receiver I get to see the PC for a few seconds before the receiver turns on it's screen-saver (wallpaper?) and I can't get it to show the PC again.
:crying:
I have tried a new driver for the computer's graphic-card, tried setting the wallpaper off, nothing helps.
Any idea on how to solve this? ? ?
Thanks!
Dror
Sounds to me like a HDMI handshake issue, very common problem with this sort of connections. Make sure your sending the proper resolution and refresh rate.
Thanks for your replies!
So, where can i find more info regarding the "handshake" procedure?
Is there any way to check this?
:ponder:
I guess that the resolution is right (both devices support 1080p), but how do i know what is the right refresh-rate? (should i send a refresh-rate that fits the receiver of the TV ?)
Thanks!
Dror
The "handshake problems" are not fixable sometimes it works and sometimes it wont. Lots of people have good luck with it cooperating but for others its a nightmare.
The refresh rate is the Hz and should be set to 60Hz on your PC. The receiver will not likely accept any higher setting or pass through anything higher. The display will however take some other higher settings.
HDCP Strikes Again!
Sorry, misery loves company.
And did you hear the news just to make things even more ridiculous there is apparently a HDMI version 1.4 coming out soon. :gah: I've just about had enough with these HDCP issues as i am sure thats why my Samsung ocationally drops the video when playing BluRay movies.
I wouldn't worry about HDMI 1.4 too much. I think it will be years before we see any products, and these new connectors just aren't going to fly. It's going to have to take a very compelling product category, probably centered in some way around the data channel, to bring 1.4 into the homes.
Not really, Going back to the PC directly to the display may be your best option. Or try a different graphics card.
Discussion Starter · #15 ·
Problem solved!!! :yay2:
Seems that the problem was with the HDMI cable from the PC to the receiver.
I got a different cable, and now everything works just fine (including the sound via HDMI)
I guess that there are HDMI cable that are not compliant with HDMI 1.3a
So, if you have a problem, do not give up !
Hope this will help to others.
Cheers, :jump:
Dror
1 - 15 of 15 Posts
