Two months ago I purchased a pre-owned Yamaha RX-681 AVR and have been trying it out in 2.0 before adding a center speaker.
I really like the sound for music w/ my 99db Klilpsch Forte speakers because of its vast soundstage, midrange clarity, and tight tuneful bass, but adding a timber matched Heresy for a center channel is not feasible because of space.
Now there is something captivating and organic about the sound for movies/TV/music with my Dynaudio Emit 10 monitors, so I'd like to build a multichannel system around these small monitor speakers set on Target Audio stands.
The question is this: The AVR is only 90wpc @ 8ohms with only 2 speakers and the 86db Dynaudios require me use the volume at -10 to -6 to get dialogue clarity on some programing, particularly British TV shows as an example. It can sound blaring at high volumes for effects and movies music at this volume. Will I have a problem adding a 85db Dynaudio Emit 25C center channel into the mix to add clarity to the dialogue. Can the Yamaha handle the extra load w/o adding and extra power amp. Lastly, it will be a long while before I can add a subwoofer because of my budget and not wanting to disturb the neighbors in our townhome community. The space is a 22'x18' living/dining room space in our townhome.
Thank you kindly,
Mike
Thank you kindly,
Mike
