1 - 4 of 4 Posts
Hi,
I am about to change my mind (from Heco Victa speakers) and I'm going to match a Yamaha RX 473 receiver with either Tannoy Mercury V1 (fronts), VC(center) and VR(rears), as first choice, or, Q Acoustics 2020i (fronts), Q A 2020i Centre and QA 2010i (rears), as second option.
They will be set up in a small room (10x11 feet), the rears will be placed on the back wall, on the corners; listening position on a couch against the back wall, between the rears.
Which do you guys think I should go for, the Tannoys, or the Q Acoustics?
I have no possibility to listen to them first.
I will watch/listen about equally movies and music (symphonic, jazz, rock).
And if I'd go for the Tannoys(the rears are designed to be wall mounted), should I place the rears facing each other (in the corners) on the side walls, or facing the fronts (still on the corners), so on the back wall?
Thank you.
Discussion Starter · #2 ·
I don't find a way to change the thread title - but it's obviously Q Acoustics, not Q Audio :)
Good idea, I just did that.
1 - 4 of 4 Posts
