1 - 3 of 3 Posts
Good afternoon!
After reading some of the posts in the DIY-Subwoofer forum I'm after a recommendation to connect my receiver to my amp. Should I...
Use an RCA to 1/4" Mono cable and run with it.
-or-
Use an RCA to XLR cable and run with it.
-or-
Use an RCA to XLR cable and go to a Samson S-Convert bumpbox, then XLR to the amp.
-or-
Something else?
The reason I ask is, the post I read explained how there's a signal difference when simply connecting the receiver to the amp without a bump box. The bump box increases the line level to what the amp is expecting. Does this make any sense? Thanks for your thoughts.
-HD
HowdyDudy,
If you find you need to match impedances and need some more gain, you might want look at the Reckhorn B-1 crossover. It gives you an adjustable subsonic frequency filter, high pass filter, bass boost and a master gain control. I'm running some big subs with my NAD hooked up to two QSC 1450 pro amps and I couldn't be happier. I'm also able to turn off all of my filters on the QSC amps so the B-1 can control and protect my drivers. With the amp's filters turned on, I loose some bass. I only need one B-1 to handle both amps.
Mike
1 - 3 of 3 Posts
