1 - 5 of 5 Posts
Given the parallel wiring, about 3ohms from 200-300hz. A stable 4ohm amplifier would be a better option. It's a fantastic design though and should still be considered IMO. Go sealed and crossed to a pair of sealed subs. I'm working on a modified sealed version of the waveguide TMM that's almost complete of the finishing stage. Listening impressions are amazing. With all the great deals on AVRs these days, sounds like a perfect time for an upgrade considering the savings of building the BAMTM!
I could swear there was a chart of it floating around somewhere but I cant seem to find it. They are considered 4 ohm but dip to 3 for a bit. I run them from a hk 347 and have never had any problems. If you are set on an 8 ohm design check out the tritrix here.
http://www.geocities.com/cc00541/Tritrix_pg_1.html
1 - 5 of 5 Posts
