1 - 3 of 3 Posts
I have tried this in mac and windows, the r16 is recognised, but I can't figure out how to get REW to find the inputs for the loop back tests, if this isn't supported can I just used the stock sound card inside macbook? Any ideas are welcomed cheers
On Windows I think you would need to use ASIO drivers with something like that. Fine to use the Macbook's built-in audio as long as it has separate line/headphone out and line in connections.
1 - 3 of 3 Posts
