221 - 240 of 245 Posts
Would you mind making a file for this driver? I do not have real measurements.
http://celestion.com/product/96/ftr123070c/
Use this order to create your own WinISD file:
Enter Mms and Cms
Enter Sd, Bl and Re.
Enter either Qms or Rms
input Qes.
Enter Hc, Hg and Pe
Enter the number of voice coils.
Correct Znom (nominal impedance)
Enter Xmax and any other missing parameters
I'm curious, why are you posting them in a .zip instead of a .wdr file that allows it to be directly downloaded to the 'driver' folder?
TIA,
GM
So I see the HST-18, but dont see the HST-11, HST-12 or HST-15 WinISD files. Anyone have them?
Sorry if this has been asked before. I can't find the answer.
I have been using WinISD. I'd like to switch to WinISD Pro. Downloaded and installed it.
I have entered many drivers into the WinISD database. I can't find the database on my PC. Is it somehow possible to migrate that WinISD user database into WinISD Pro?
If so, where is the data kept in Win 7?
Thank you in advance,
Stuart Polansky
Stuart Polansky
It's located in your "my documents" folder
Which PRO version are you switching to? This is the latest, best version to use: http://t.co/0eYfbFVo
Also, never messed with the basic WinISD, but curious if you can just change the existing driver file suffix to .wdr and add them to the new 'drivers' folder.
GM
