And also, how many decibels is when things start getting a little crazy... windows/doors/pictures moving around and stuff?
Thanks!
Thanks!
I concur. This may be too loud for concert BluRay on a projector setup, as the picture will get fuzzy 10 dB before you lose focus on the meter. It is a great reference for audio only.lcaillo said:When your eyes get fuzzy and you can't read the display on the meter anymore, the last value that you read is loud.![]()
Is this how we should be tuning our subs for accurate reproduction? Or is this filtering already implemented in the media and subs should be tuned flat as low as possible?revboden said:More specifically, THX LFE ref. spec is 115db from 80Hz to 63Hz with a F3 (112db) at 31.5Hz and F5 (110db) at 20Hz.
cheers,
revb.
