X-19 Specs
specs x19
12K views 56 replies 25 participants last post by  imported_m-fine
#1 ·
X-19 Amp - A 25 WPC (4 Ohm) amp with a 100 Hz crossover to a subwoofer out, Bass and Treble shelving controls, Mute, and an attractive overall look.
Just thought I'd bring some specs over. Craig... My only complaint with the BPA-1 is no remote. That is until I have heard yours. ;)
#3 ·
Here is a pic of the new Digital Amp ... As Buzz3 already stated, it delivers 25 WPC into 4 ohms, and has Bass, Treble, Mute and Standby switches on the front panel.
It also has a subwoofer out which crosses over @ 100 Hz.
#5 ·
Maybe the answer should be obvious, but is the crossover defeatable / auto switched, for use as a 2.0 system? Or does the frequency response falloff (like the original Sonic Impact T Amp) or ability to deliver power make that a bad idea?
Approx. dimensions would help at some point but you can eyeball it from this. While you're eyeballing checkout the other thing on the right side ...
#6 ·
Any chance that the adventurous of us can modify the crossover point by changing some values on a circuit board inside the amp? I like the idea that it had a crossover, but I'd like something lower.
Also, can the crossover be defeated (running the amp full range)?
#7 ·
The single input is very limiting. I may just use this amp in the guest room connected to a CD transport. I have a separate vintage Phillips tube stereo radio in there in case someone wants to listen to FM. Second thought, I recently disconnected the guest computer/monitor/HD tv from the Dish HD antenna. It just caused too many problems. I'm going to do a separate small HD tv in there with a DVD player, not a CD only, and that way they could play movies if they want to, or CD's and not risk messing up the computer. My wife and I don't have any movies. We're just not movie people but sometimes guests are, I suppose. They can go to the store and rent a movie. I did that once. I forget the movie. It was funny. I forget what it was about now.
Most guests use iPods. Shanling got a good review for their $999 music system, but I've been looking at several others less expensive -- the AudioEngine 5 has a built in amp and USB and it has received great reviews; also, the KingRex USB.
I collect vintage radios. I just bought an AM transmitter kit. Once I get it put together and "tuned" to an unused AM frequency we can hook it to out stereo and listen to our CD's or the FM tuner on any of the AM wonderful old radios in any room or out in the workshop or barn and get that great old tube radio musical sound.
I'd like to have an attractive "switch box" for the X-19. I think that's what I need. I found one (Google "Ampbox" and look around). If I had some schematics I could solder one together. I think that's what I need -- a box with a selector switch and RCA inputs for tuner, CD, a place to plug in a turntable phonoamp or headphone amp -- that outputs into the amp's single input.
Jolida sells a nice "Remote Control" platform. The amp plugs into the platform which is controlled by the RC. All it does is "on-off", but that sure beats getting out of bed.
However, I don't want to overlook the fact that this sounds like it is going to be a very nice first product and I don't want to distract from that. I'm sure many more good products will follow and I'm eager to read about them and perhaps have useful input as they are going through R&D.
#15 ·
Craig... Is it at all possible to make a run of these with remotes? I really think it will sell. I love my BPA-1 in the MB but I have to get up to set the volume or hope to catch the kids walking by. ;)
#17 ·
Once we get the basic Gizmo up and running, look for a "deluxe" version ... possibly a remote, USB input, a 2nd set of RCA inputs ...
what about a headphone out? will that be squeezed into the deluxe version? (my pc is in my baby's room, and sometimes I need to use headphones)
also, i didn't see size specs in this thread ... what's the tentative size?
#19 ·
Hey, I'm currently using 2 channels out of a 7-channel, 100wpc surround receiver/amp by yamaha for my 2-channel listening. You think the Gizmo would do better than this (considering you're paying more $/Watt, you'd think it should)? Not to mention I'm saving space by going with the Gizmo.
#20 ·
Klankymen - The Gizmo is just for that purpose - saving space while providing high end sound. I will compare it to our Onkyo 674 receiver on a pair of 760's when my beta unit arrives.
Seth - Let me get the original unit up and running, then we can start talking about further enhancements. Anytime I tell the guys to change something, or even to look at other options, it pushes back delivery.
Thanks for the patience, guys ... :thumbsup:
#22 ·
Craig, are you saying that the features are fixed for this model, or just for the prototype :scratchchin:
it'd really be a super feature to have headphones out on the FINAL unit
:thumbsup:
how much shipping are we looking at within the US (or to California)?
also, will there be different wood finishes? or is this fixed as well?
#23 ·
Mike -The initial unit will not have a headphone out - everything has been fixed.
Any changes and we are looking at moving back the launch by a couple of months. Shipping will be pretty minor, but I have not gotten a quote yet.
Thank You
Craig
#25 ·
Thank You
Craig
My 2 cents... this is the better approach. Especially given what else is out there (T-Amp varieties)... it lines up square against the competition.
By offering alternate versions, the customer will have options and won't be "stuck" buying extra features if they don't plan on using it.
My only suggestion (and I would expect it's being done)... the ideal situation would be to have the same basic design/MB for all versions... the cheaper versions would just be depopulated of the respective components. Helps keeps PCB costs down (having one common MB). The same theory could be applied to the case... your faceplates look to be screw on varieties, so that would be the only thing which would need to be updated in order to accommodate jacks/switches/etc.
