Is it a bug?
bug
1.8K views 10 replies 2 participants last post by  JohnM
#1 ·
Hi folks,
For some reason and since I've proceeded with the beta 8 ver., the tabs on the left hand side do not expand and at the same time the right part of the screen, which is the main window, does not follow my choice according to the measurement tab I click on. Any clues what could be the reason? Before the upgrade everything was working smoothly.
Thanks,
Harry
#4 ·
Please attach some of the log files with error information here so I can take a look at them, could also be useful to attach a measurement that shows the problem. You can try installing the beta 7 (previous) version to see if that helps, it is available from the same place as beta 8.
#5 ·
John it seems that new measurements, after the reinstallment are working fine, without problems - I tried without any sound card connected. Anyway, I post the last problematic session with only 2 measurements (keeping the file small). Thanks for your support.
PS. I'm not sure if I'm posting the correct TXT file.
#7 ·
Oh...It could be anything of what you mentioned. The initial mdat file had more measurements but I deleted them in order to be able to post it to the forum. When I ran back to the 7 beta version, corrupted file still had the same problem. When I'm loading older measurements everything is fine. The only thing I'm sure of is that I was adjusting the ETC smoothing to 1ms for each curve. It would be nice too if in the viewing preferences we would be able to choose ETC smoothing time, so as not to re-adjust it for each measurement...
Thanks,
Harry
