61 - 80 of 168 Posts
Discussion starter · #61 ·
I know it! I was very thankful not to have had the flooring down!
Well it wasn't the ice that initially caused the problem, the pipe had been buried by grass so it wasn't flowing well enough to begin with. Our house was built in 2012 and I never knew where the pipe was nor thought to even ask. Now that I know where it is I can keep an eye on it year round and make sure it's clear.
Water is my biggest concern for when we eventually do the basement. It is dry now, and has been for the 5 years we've been here except for a tiny spot that weeps a minute amount in heavy rain. I'm hoping to spray foam and take care of that but you never know where water could come from.
If you can see where it comes it, I would opt for a concrete sealer - I had a crack in my foundation and sealed it one tube of that and I have had no issues since...
Thanks Joe. It was actually "fixed" by the builder while we were still under warranty, with that thick, heavy rubber stuff that you drill out and inject. Seemed to do the trick except for a tiny tiny bit that still comes through under heavy rain. Anyway, sorry for the derail, I'll look into some additional sealer. :)
Discussion starter · #65 ·
No problem derailing my thread.
Honestly my build has stalled yet again due to my architect registration exams. I'm taking one in two weeks so I'm focused on studying. I'll probably finish hanging drywall soon though and then caulking EVERYWHERE. At least that's what's next on my to-do list.
I bought some plywood to build some shelves in the storage room this past weekend so that I can get stuff up off the floor that isn't in totes. That's priority at this point. And I'd like to use up the rest of my lumber to make more work space which means framing the rest of the basement walls. So much to do, so little time.
I'm tentatively setting my finish date on the HT a year from now so that I'll be ready for Super Bowl XLVIIII (notice the 4 I's?). :D
Discussion starter · #67 ·
Took my exam this morning. Its been too cold in the unfinished, unheated basement to work. I've got a few space heaters to help. I plan on working on the room this weekend. Trying to get my mom to watch my kid so I have more time to work. I should be able to finish up hanging the last pieces of drywall and start sealing all the gaps and joints with caulking.
Discussion starter · #69 ·
Woohoo!!!
This build just got a swift kick in the pants!
Thank you Sonnie! I've now got a MAJOR piece of my room's puzzle! Now to research this Panny and figure out how to use it in my room.
Should I go with a 120" DIY spandex screen or this 106" Accuscreen HERE?
Soffit placement should put it at about 14 feet from the lense to the screen...
Discussion starter · #72 ·
I have gmail and it was in my "Promotions" folder. I don't know when it arrived since I hadn't checked that folder until I got into work. It doesn't alert me to emails received in that folder so I found out about me winning by seeing someone post it in the giveaway thread. I confirmed I am subscribed to the newsletter but didn't know it would get filtered in the promotions folder.
It's funny because last night I thought to myself, "If I won, I wonder if Sonnie pronounced my name correctly when he "said it outloud"." :rofl:
Discussion starter · #74 ·
Thanks guys!
I've been meaning to borrow my dad's space heater so I can finish up down there. The basement won't be heated until the family room is complete and I get a fireplace installed, hence why I haven't put in a lot of time lately in the room. This has given me motivation to get back at it!
Congrats on the new projector.....well done!
Discussion starter · #77 · (Edited)
Got the OSB cut for the storage room walls. The battery died on my screwgun so I wasn't able to hang all of them but at least they're cut and in place now. Soon I'll build the shelving units out of the scrap OSB and some 2x4's. Most of our stuff is in plastic totes but the shelves will keep what we don't have in the totes up off the floor and more organized.
Entry door opening is framed out and all the insulation is in. I couldn't decide on what size door to get and had already framed the walls, hence the additional jack studs at the opening to accommodate the smaller door I picked.
These three Lutron dimmer switches that are right inside the entry door will control the room cans in the soffits, the 3 cans over the screen and the riser lights and rope lights within the tray.
I got a couple more sheets of drywall hung and cleaned up a bit too.
X marks the spot! Behind this layer of drywall and the X is plywood blocking for future front height speaker brackets. I put electrical outlet boxes with monoprice in wall speaker wire from the closet to each speaker location. I've got monoprice speaker plates that I'll have to paint black for each of the 7 locations I've got in place. If I decide to go with rear surrounds later on I've prewired for ceiling speakers to be installed in the soffit.
I'm using black Leviton Decora outlets and covers throughout the room.
I ran monoprice's "high quality" CL2 rated RG6 cable for the subwoofer amp connection to the stage along with speaker wire to the LCR locations. I ran an HDMI cable from monoprice, CAT6 and pull string within the conduit that runs from the closet to the PJ's future location. I've got plywood blocking installed along with the wiring and boxes for the side surround speaker locations.
This weekend I plan on putting up more drywall of the pieces I have left to finish up the soffits. I'll need ten more sheets to complete the room. I'll be hanging the ceiling insulation once I get the drywall so that I can do both installations at the same time so that the insulation doesn't sag and rip at the staples. Then its on to caulking EVERYWHERE at all the seams, the top and bottom of the walls and the outlets. Some of the outlets need extension rings, so I'll pick those up this weekend too. And I need to buy a 3" hole saw to cut the holes for the can lights.
I still have to add the blocking within the soffit for the PJ box to hang from. Once I get it in and the drywall done I can start thinking about how I want to get the PJ up there. I might just build a "hushbox" although make it more like a shelf with vertical supports on either side of the PJ and leave the front and back fully open so it can easily transfer air for cooling. Of course I'll take pictures so you'll see what I'm talking about.
Because funds are a bit tight right now, I'm going to have to wait on the rest of the drywall. But I've got enough hung that I can finish up the front of the room and start building the stage. I've got all the lumber I need to construct the stage and the riser, except for the plywood (I do have 3 full sheets of 3/4" T&G for the stage though). I've got a bunch of sand, roofing felt and plastic sheeting for the stage as well. So as soon as I get the front of the room sealed up I can start building it. I bought a roll of carpet pad a while back too.
I've got the ten sheets of drywall, rope lighting, carpet, plywood for the stage and riser and the DIY screen materials left to buy which is not too bad. Oh and one more RF-62 II for my center. It's coming together! :T
