Phantom Center?
9.6K views 10 replies 8 participants last post by  Trick McKaha
#1 ·
To avoid jacking another member's thread I have a question about a Phantom Center, what would be the conditions to use this approach and how would one go about doing this properly?
#2 ·
The conditions for using this are:
1) You have no center channel
2) You have no place to put a center channel
3) Your center channel placement would be way out of line with your left and right
4) Your center channel is horrible and dialogue is muddy.
To implement this you generally just turn your center channel off in your AVR's menu and it will automatically start using phantom center mode. Some receivers require you to set a separate setting for Phantom mode but it's generally under Speaker Setup or something similar.
#3 ·
Thanks Dave, I now understand the reasons why now, will you need to re-run Audyssey? also how will others who may be sitting off-axis be affected?
#5 ·
Thanks Dave, I now understand the reasons why now will you need to re-run Audyssey?
In theory, you should not but, depending on the implementation, Audyssey may require re-running with any change in speaker configuration.
Off-axis listeners will suffer less stability of voices and center-imaging.
#4 ·
Cant really say more than what Dave has said. If at all possible you should use a center channel however in the case where it wont fit or just does not sound good, Phantom is an option and works quite well. I've been using it on my living room system for about 3 years.
#6 ·
Thank you Tony and Kal for the info, if Off-axis listeners suffer would expanding the width of the fronts help, example move speakers from 6ft to 9ft apart?
#9 ·
The kind of speakers you are using makes a pretty big difference as well- Some fronts will mesh with each other almost perfectly from across the screen, and others will leave a gaping hole without the center.. It all depends on what you're using, and you just need to give it a listen and see how it does. When I got my RF-5 towers (my first big buy!), they were such an improvement over the Synergy speakers that the old center dragged the towers down pretty badly; It became necessary to go phantom until I was able to get a RC-3ii to match the towers, and luckily the horns were able to match up pretty well with the right placement. It was still a huge improvement when the new center came in though, so you should definitely at least try to get something in the middle if it's feasible
#10 ·
One reason is simply lack of funds. I've been telling people building a system with limited funds to buy the center channel last. IMO, you can get by without the center easier than the other speakers.
