The beta release of V5.01 is now available for download in the Downloads Area. Use the "Drivers" selection box at the top left of the Soundcard preferences to select ASIO then choose the ASIO device, input and output. For most reliable measurements use normal or high latency settings on the ASIO driver.
Changes in this release:
Please report any issues in this thread.
- Added support for ASIO drivers on Windows
- Updated help to add All SPL graph to GraphPanel help
- Tried a tweak to have the big-endian output flag default to on for OS X PowerPC platforms
- Stimulus trace on scope plot is shown at level sweep was made at rather than 100 % FS
- Added sample width selector for dither control on sig gen sine wave generator
- Changed VU meter labelling to show "In" and "Ref In" for input meters with actual input name/channel in tooltip
- Show an error message if user attempts to load an mdat file as a mic/meter or soundcard cal file
- Allow ";" as line comment indicator for imported ASCII files (used by SMAART)
- Added a check on soundcard calibration measurements to warn if measurement appears invalid
- Added impulse response export options to export windowed response or minimum phase response
- Added a warning message after SPL meter calibration if the input level was below -50 dB FS
- Added a MiniDSP-96k equaliser option for 96kHz MiniDSP plug-ins (e.g. for 2x8)
- Added parallel equivalent impedance display for impedance traces
- Bug fix: TS parameters calculation could fail for some measurements
- Bug fix: Problem opening EQ panel with a measurement generated from Trace Arithmetic
- Bug fix: Target trace in EQ window did not include house curve when there were no measurements loaded
- Bug fix: Do not use physical fonts unless default Locale language is en to avoid undisplayable characters
- Bug fix: Export RT60 data as text was broken
- Bug fix: Fill filter traces filled the house curve section of the target if a house curve was loaded
- Bug fix: Force use of decimal point as decimal delimiter in SPL meter SPL value
- Bug fix: Adjusted DCX2496 centre frequencies
- Bug fix: Error when trying to upload TMREQ filters from surround or surround back channels
- Bug fix: Exporting filter impulse response as WAV always exported the set from the currently selected measurement regardless of the selection made in the export dialog
- Bug fix: Path to last imported impulse response was not saved correctly on exit
- Bug fix: Hilbert transform had an error that affected envelope calculation
