61 - 80 of 167 Posts
Pardon my dumbness but I know little of Audyssey. Are these measurements taken with all speakers running, just the front L/R, or the front L/R one at a time?
And does the system apply EQ to each speaker individually?
It measures each speaker one at a time and applies a separate EQ to each speaker as needed.
In that case I expect this is the source of the problem where imaging is concerned. Back in the mid ‘90s when I moved up to high-end equalizers I learned pretty quickly that applying different filters to the left and right speakers above about 3-400 Hz whacked out imaging. I thought perhaps it was because I only had 1/3-octave equalizers at the time, but in recent years, others here on this Forum have confirmed that even with precise parametric equalization they’ve had the same experiences as well.
What a lot of people don’t know is that equalizers accomplish response changes by introducing phase shift at and around the filter’s center frequency setting. With analog equalizers this is accomplished with capacitors and inductors, and with digital equalizers it’s done with taps on a digital delay line. But the fact is, without phase shift equalizers would not work at all. So basically, equalizers use time domain changes to accomplish frequency domain changes.
So why did the mismatched filters mess with imaging? Because a phase change was introduced to one speaker in a certain frequency range, but not the other. Either speaker played independently would sound identical because frequency response was appropriately matched, but played together you get the phase differences and the resulting dislocalized imaging. This is why I’ve typically recommended for people to use matching filters above ~3-400 Hz for the left and right speakers when performing manual equalizing.
The next issue I see, unfortunately, is the wonders of modern computing power. Before the advent of cheap processing, room analysis and equalization was limited to 1/3-octave resolution from both hardware RTA devices and equalizers. That seems quaint and outdated these days: Chris Kyriakakis claims Audyssey MultEQ XT can introduce hundreds of filters, and MultEQ XT32 thousands, to “make corrections to narrow peaks and dips in response,” in his words.
But is this really necessary? Anyone who’s ever had hands-on use of a good parametric EQ (or possibly even a cheap one) will tell you that filters with tiny bandwidth and gain settings get you nothing audible with a program signal. Has Mr. Kyriakakis spent more time in a computer lab than hands-on with actual hardware in a playback system? As I mentioned years ago in my minimal EQ article, what’s the point of peppering the signal chain with a bunch of inaudible filters?
Audyssey utilizes FIR filters which are designed to address time domain (phase) as well as frequency response issues, but the phase issues the filters address are from the room. Maybe I don’t know enough about EQ filtering (very likely), but filters that address phase generated by the room (which isn’t necessarily all bad, by the way) seem to be of diminished effectiveness if they in turn introduce phase of their own.
Wayne’s research from his excellent Audyssey MultEQ FAQ and Setup Guide has confirmed that multiple spread-out mic locations might give improved frequency response over a broad area, but that imaging suffers as a result. I expect the cause of the poor imaging is that this approach results in drastically mismatched filtering between the left and right channels (someone could probably loop an Audyssey-equipped AVR through REW and confirm this).
Thus Wayne’s recommendation on tight mic spacing when running Audyssey is a step in the right direction: Frequency response isn’t going to change significantly a few inches this way or that, at least above ~500 Hz. As a result, Audyssey probably performs less aggressive equalizing – hopefully only a few dozen filters instead of hundreds or thousands – and the result is filters that better match for the left and right speakers.
But is even this tight mic spacing necessary? Try this little test: Turn off the sub, disconnect the left or right speaker, play a broadband pink noise signal through the remaining one, and move your head a few inches away from, and around, the dead-center position – i.e. places where you might locate the Audyssey mic for a tight measurement pattern. Do you hear any audible change in the way the speaker sounds? Not likely, or if so not enough matter. How ‘bout when you move from the center seat on the sofa to the left or right? Probably the same. (Note, we only use one speaker for this because with both you’d hear a change with a mono pink noise signal once moved off-axis from dead center, due to timing [phase].)
The fact is that measurement mics are more sensitive to subtle location changes than the ear. And thanks to the power of cheap processing, that hypersensitivity can be translated to scary graphs that show visible changes in frequency response that the ears simply ignore. Or to a processor that generates “correction” filters to address problems that aren’t audible (introducing phase in the process). So even with the tight spacing technique, with the mic at locations where you can’t hear a difference yourself, Audyssey most likely is still introducing filtering that is offering no audible benefit – at least some, but probably a lot.
So the single-location approach to Audyssey and similar systems makes perfect sense to me. And the experiences of Wayne in his exhaustive evaluations and Talley’s experiences in this thread seem to bear this out.
I’m not saying here that Audyssey and similar systems are overblown and useless, only that some people’s experiences with them only seems to reinforce the idea that minimal EQ is more effective than hundreds or thousands of filters.
Wayne, for your next test maybe you can compare Audyssey or Dirac to manual equalization with a first-class parametric EQ and see if the former really delivers better results, either with response or imagining. :T
Great post, Wayne, and some interesting points. And so the pendulum swings . . . Sometimes just because you can doesn't mean you should. I like your suggestion to the other Wayne (Audiocraver). I know he has used EQ via a plugin for foobar in the past so maybe he already has some ideas about it.
Regarding the idea of placing the measurement mic on top of the head, that's quite clever. I would have a couple of reservations about it. First, you'll want to ensure that the thing is still pointing straight to the ceiling, not significantly tilted one way or the other (especially forward or backward). The other is that the mic will be significantly above ear level, as already alluded to. Solution for that would be to slouch during the measurement.
The mic tip being above the head (especially combined with it being tilted to the rear of the room) could result in the mic picking up lower SPL at the higher frequencies, leading Audyssey or Dirac to boost that area and create a bright-sounding FR.
I've found that the easy way to tell if room correction has hurt your imaging by simply selecting pure direct mode. Listening to the difference between that and stereo if Audyessey made any bad changes to the eq on the left or right channel it will be evident right away.
Room acoustics and speaker placement are the biggest factors in getting a good front image I can't stress that enough.
Discussion starter · #65 ·
listening now....
...for sure I'm sticking to my very tight 6" square 8 mic position with repeating center position 3 times setup.
imaging is amazing... pinpoint accuracy
Apologies if I missed it. What single-point mic position would you recommend for a high seat back? Would a different mic type help? I'm thinking a cardioid in front of the face.
High seat backs are comfy, but mess with the acoustics around the head. Even with a plushy blanket thrown over the seat back, there is enough reflection to cause a cancellation and dip in response at the ears. Use the regular omni Audyssey setup mic at the center-of-the-ear-line location. It will correct for that dip. Realizing that we are less sensitive to such dips, it is a broad dip and does take away some from definition and image clarity. The correction makes your soundstage & image clarity much better and a little more position sensitive than without, but that is part of the tradeoff with high seat backs.
Ear line to back of head is 4", but we usually sit with head forward a little, so 6" is a good distance. Closer and the dip/correction both get more severe.
Pretty sure the Audyssey setup mic is omni-"ish", at low through mid freq anyway, will be less so at HF. Will measure mine and post a graph.
Discussion starter · #67 ·
I suppose that is a good reason my couch is lower in the back. the back of my couch is about even with the top of my shoulders so my entire head pops up above it. If I sit at the MLP then my head is on average 2' off the wall but I also put a computer chair in front of the couch for critical listening and that puts my head at 3.75' off the back wall which is exactly 25% of the length of the room, the back 25% which is suppose to be right on the ideal mark.
For bass response at least, and in a rectangular room, nulls and peaks will be found at 1/4, 1/2 and 3/4 of the dimension of the room. You'd be better off at around 1/3 of the room's length instead (or 1/5 if it's not too close to the wall for other considerations).
Discussion starter · #71 ·
Golden Mean: 0.62, or 62% of room length.
In my case room width.
Unfortunately/fortunately I have full freedom to do whatever I want with my room when it comes to the WAF factor... except:
1. Must have room for Christmas tree in corner every Christmas season.
2. Must be setup along the long walls (backward to a normal rectangular setup)
Considering this it throws everything off.
So far my room response is decent. I can't complain really. Just need to tame the wild echo/reverb/flutter that I have.... which is coming soon.
If I may add my little contribution here. I am neither an expert nor a sound engineer.
But I made a lot of experiments in a little room with YPAO.
My chairs must be at 18 inches from the back wall and I can not have more than one sub if I want to avoid divorce procedure (32 years later it would be stupid !)
Recently, I used an Excel room mode calculator. IF I understand well the theory, I discovered that at my main listening position (MLP) I had (by chance !) width and height mode null of 2nd, 3rd or 4th orders for 75hz or 147hz. More, my sub (it is between the center and the right front main speaker) was right on a width mode null of the 2nd order i.e. 98 hz (147hz is the 3rd order of 98hz) making that 98hz FR not existing because was not excited by the sub.
The automatic EQ of the receiver used a lot of filters only to attempt to get rid of this approx 150hz null. For ex. 3 filters at 150hz for the right channel, 2 filters at 300hz for the center.
A pattern of 8 tight mic spacing positions helped but I never get good results (dialogue in a tunnel like effect).
Now, I cheat a little bit...with the mic position not in love with my wife !!.
Always keep a tight mic pattern and the first measurement at MLP. But positons 2 and 3 for ears (3 inches left and right from the MLP) are moved 3 inches forward between the nulls of the 3rd and 4th order of width mode. I moved the sub backward of 3 inches to be sure that it is in between the 2nd and 3rd axial width modes (between to make sure that 98hz and 147hz order exist) .
For the height of the mic I moved it 1 inch upward my ear height to be sure to put it in between the mode of first and 4th order (75hz and 150hz).
Also, for the last 4 mic positions, I take care to never put it back on the same width and height planes that gives the mode null of any orders.
Then, YPAO uses filters for different frequencies instead of 3 filters at 150hz to add 5.5 dB with a large Q.
I gain in sound stage imagery and more in sound quality.
There are a FEW things in life more important than good sound.
Interesting, they seem like small moves to make a significant difference at the wavelengths involved with such low frequencies, 15 feet for 75 Hz, for example, but I guess if you are talking about avoiding actual null points, very small moves can make a significant difference around a null. And you cannot argue with results.
Well done. "Yeah science!"
A couple of discussion points in this thread have gotten me thinking, and I took some measurements which have been posting in separate threads because there may be people interested who are not following this thread.
The first is concerning the Audyssey setup mic and its directionality, which is not what one would think of as an omnidirectional pattern. It has some funny frequency response patterns depending on which angle you are looking at it. It is posted for in this Audyssey Setup Mic Directionality Pattern thread.
The second area concerns the single mic point setup approach and its validity, especially relative to a high-backed chair. There are several measurement graphs and some discussion about that in this Data Supporting a Single Setup Mic Position for Audyssey or Dirac Live thread.
High seat backs are comfy, but mess with the acoustics around the head. Even with a plushy blanket thrown over the seat back, there is enough reflection to cause a cancellation and dip in response at the ears. Use the regular omni Audyssey setup mic at the center-of-the-ear-line location. It will correct for that dip. Realizing that we are less sensitive to such dips, it is a broad dip and does take away some from definition and image clarity. The correction makes your soundstage & image clarity much better and a little more position sensitive than without, but that is part of the tradeoff with high seat backs. Ear line to back of head is 4", but we usually sit with head forward a little, so 6" is a good distance. Closer and the dip/correction both get more severe. Pretty sure the Audyssey setup mic is omni-"ish", at low through mid freq anyway, will be less so at HF. Will measure mine and post a graph.
It's easy to say I reached the same conclusion And you'd be right to question my credibility in the absence of supporting data, but I did wind up with decent--not exceptional--results through trial and error. Still, your distances and methodology explain a lot of postulating on my part, and I'm grateful to you for sharing :)
Sent from my iPad using HTShack
A couple of discussion points in this thread have gotten me thinking, and I took some measurements which have been posting in separate threads because there may be people interested who are not following this thread. The first is concerning the Audyssey setup mic and its directionality, which is not what one would think of as an omnidirectional pattern. It has some funny frequency response patterns depending on which angle you are looking at it. It is posted for in this Audyssey Setup Mic Directionality Pattern thread. The second area concerns the single mic point setup approach and its validity, especially relative to a high-backed chair. There are several measurement graphs and some discussion about that in this Data Supporting a Single Setup Mic Position for Audyssey or Dirac Live thread.
Excellent summary. Can we make this into a STICKY thread?
I know this thread has been quiet for awhile. The Data Supporting a Single Setup Mic Position for Audyssey or Dirac Live thread has been updated with new recommendations for Audyssey calibrations. Basically, the single mic position calibration is NOT recommended any more, by me anyway, for Dirac Live, or for Audyssey with a high-backed seat. Follow the link above for details.
Dear Wayne,
may I add to all your very good and interesting threads about mic positions that I found much better results with a blanket in polar fabrics thrown around the feet of my camera tripod (I know that a boom mic would be better) and around the base of the mic .
Dear Wayne,
Very good thoughts. Yes, every little improvement like that helps clean up reflections and leads toward another level of improvement. Thanks for the suggestion.
